メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
締切られた回答
Why no phone network detected
My iPhone 5 lost constantly its connection to the phone network 3 months after i opened it to fix its volume buttons. It couldn't even load the available carrier networks when set to Manual. The Wifi works just fine.
So I assumed that I messed up with something related to phone network inside:
I checked the "Field test" screen and it refused to load. Stuck on "loading"
I opened the iPhone and checked that interconnect cables and the 3G antenna (bottom one) were well connected. It didn't fix it.
I changed the interconnect cables, it didn't fix it.
I changed the AudioJack+LightningConnector+3GAntenna module and it didn't fix it.
Now I am stuck. Any ideas out there?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
it sounds to me like youve either knocked the network/signal ics, or something similar, if you could provide me with some pictures, id be happy to pinpoint the problem for you
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It's fairly possible, but I am quite afraid to start tinkering on the mainboard's components. I prefer an "iPod5" to a completely broken black block :-)
I'll try to get a few pictures anyway, thanks for your proposal. I don't have time at the moment, but i'll definitely do. I'll take the lower part of the mainboard at the interconnect connector, both front and back. With two lenses, that should do the trick ^^ http://www.easy-macro.com/
さんによる
コメントを追加
Have you checked the date and time settings? Often removing the battery resets it, this means it can't verify with the networks because it thinks it's in the seventies.
Hope this helps.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Good idea, (un)fortunately the wifi does work and time + date are ok.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 186
