メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
iPhone 5 Touching Itself!
Hi guys,
I purchased a used iPhone 5 the other week, and a few days later noticed that the screen had started to "touch itself". Initially this was just near the top (it kept dragging down the top menu!). When opening snapchat and using the drawing tool, it was drawing a diagonal line across the screen on its own. Also whilst typing, it would often hold down letters on its own, or the screen would freeze completely!
To get out of the frozen screen, or to stop the screen being touched down on its own I would simply turn the screen off then back on and it would be fine!... for a few secs.
My initial thought was a dodgy digitizer, so I replaced this. It worked fine for half hour then started to resume back to pressing itself!
I tried another screen, and also changed the metal back plate to the scree. Again, this would work fine for a bit then start playing up again!
Despite having 88 days warranty left, Apple wont look at it free as I've removed the screen myself... which apparently voids the warranty.
I'm stuck for ideas!
I've already tried doing a restore! Once from the phone and ones via iTunes.
Stuck for ideas, but it's really annoying! I can't even send a txt properly now without having to turn the screen off then back on a few times to avoid buttons being pressed or it pressing back to the prev screen!?
Any suggestions would be great!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
2件の回答
最も参考になった回答
Cover this part either side with electrical tape and test screen.
このアンサーは役に立ちましたか?
スコア 1
7 件のコメント:
Still no joy as suspected. I had already previously replaced the whole digitizer too
さんによる
Mmmm could me motherboard damage
I would try apple again but never mention anything about opening it up
さんによる
Just did a motherboard swap to a working iPhone. Same issue! Guessing its the m/b or software. Will try another complete wipe again...
さんによる
At least now you know its not the screens fault
さんによる
Did a complete wipe, whilst it was in a completely new shell etc. Still an issue. HAS to be the mainboard :( Looks like a new phone for me :(
さんによる
2件以上のコメントを表示
コメントを追加
Hello everyone who has the issue, there are 3 options/ steps to try before buying a new screen or phone...
1. Check if your phone is bent in anyway. :if it is try to bend it back with medium presure. Make sure not to push on the screen. If it isn't move onto step 2
2. Search how to remove the ports to the LCD and display digitiser on Google. If the issue persists move to step 3
3. Your IPhone is broken, go and buy a new phone sorry ;@
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Josh Townsend さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 12,812
