メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
締切られた回答
After screen replacement, slight discoloration on top right of LCD.
I just replaced the screen on an iPhone 5, and after reassembling it, the screen on the top right (Right above where the display cable bracket is) is discolored, slightly yellowed. It seems like it must be from pressure. When I remove the plate and replace the screen, the discoloration goes away. I have verified that the cable are secured correctly (Camera, digi, and lcd all work), and there's no bunched cables, and all the screws are secured tightly, and there's no give in the bracket, and i made sure the left side of the bracket was hooked under the logic board.
I have had this happen one other time. At that time, one of the screws stripped, and I just had to put it back together without the cable bracket, and informed the guy that if he had any issues, to bring it back to the store and we'd take care of it, but i'd rather actually figure out why it's happening.
The one thing i'm not sure about is the tiny black gasket/spacer underneath the Earpiece Speaker bracket that's in-line with the top screw for that bracket. Could that be on wrong, causing the pressure and therefore the discoloration?
Any other suggestions are appreciated
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
So, i left it overnight, and this morning, I screwed the pentalobes back in, and turned it on, and the discoloration is gone. I wonder if maybe things just needed to settle?
さんによる
コメントを追加
3件の回答
The pressure from the plate has settled
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
That has happened to me before and it was an easy fix. It occurs from the two screws that are used to hold the speaker and bracket in on the back of the screen display being too tight. All I did was loosen the two screws a bit making sure it was still tight enough for the gold speaker wires to be in contact and the spot went away!
Hope this helps!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi Max B, I currently have a phone with the same issue, did you ever manage to find out a reason why this happened? Did you ever manage to find a fix?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 9,677
