メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPod charging but not fully...
When I plug it in, it shows a red sliver of battery and a lightning bolt. After a while, it boots into the OS. The problem is that it warns you there's less than 10% battery left and the battery icon no longer shows a lightning bolt. I can't get the battery to keep charging. Does this mean the battery's at the end of its life?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
2 件のコメント
Ok, I just got a better theory. I peered into the dock port down there and found that the little circuit piece is wobbly and one of the pins (it looks like #1 or #2) has been pushed into the back wall and bent up.
さんによる
I've also found out that pin #1 and #2 are grounding pins. So maybe this explains why it charges at first but stops once it boots up? I guess the OS checks for the pins and manually stops the charging if one of them is missing? Now.. if I could find a software fix for a hardware problem, that would truly be amazing.
さんによる
コメントを追加
1 件の回答
ベストアンサー
I would bet dead battery. you should be able to change it, if using one of the guides... it is an old device, battery is nearing its end anyways...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
AndrewNoNumbers さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 1,661
