メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
締切られた回答
iPhone 4s earpiece not working tried replacing
Hi, I have experienced this a few times, I had a phone come in and the earpiece does not work, I changed the proximity sensor as the power button didnt work either and also changed the earpiece but that still does not work, what else apart from the earpiece and the contact strips on the board can prevent the earpiece from working? Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Sounds like you have a bad audio chip, almost impossible to fix, sorry, if you had a 4 instead of a 4S I would have an easy fix, the only other option would be that the headphone jack is dirty or has failed and is stuck on headphone mode so all audio is being sent there when on a call, try this make a call take the phone away from your ear watch the screen, turn volume up and down while on call and see if the volume on the screen says (heaphones) while your adjusting volume if it does than you need to clean or replace the headphone jack, good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Well the earpiece is only stuck to the proximty power cable so either u have damaged the cable or it's not plugged in correctly..
And make sure u have the earpeice installed the correct way with the gold prongs pointing toward the top of the phone
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi, thanks for your reply, I know the earpiece is only stuck to the prox I was just explaining that got changed also. Yes the gold prongs are facing towards the top of the phone, I have tried 4 new earpiece and still not working, I am wondering if there is anything else that can stop the earpiece from functioning?
さんによる
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 1,404
