メインコンテンツにスキップ
80年代、90年代に製造されたMacデスクトップの総合リペアガイドです。
110回答 すべてを表示
締切られた回答
How to remove the power supply from Macintosh Quadra 650?
In my quadra 650 i want to remove the PRAM-battery. And the quadra should become new RAM. But, before i can do this i must remove the power-supply. But i dont' no why. In the Service manual they describe a powersupply-screw. But they don't show what kind of screw this exactly is. Phillips? Wich size? Where is this screw exactly? Can anyone help?
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
And "2" is exactly the problem:
what kind of screw is it?
Where is this screw exactly? Can't find them on the rear bezel. Have anybody here a picture from the position of it. The schematic in the service manual didn't help me.
But the power supply is on somebody fixed. I can't remove it after I pry the latch (3)
However the force is use
Sorry
さんによる
コメントを追加
1 件の回答
最も参考になった回答
1 If a CD-ROM drive is
installed, squeeze its
side tabs and pull the
drive out an inch or two
to more easily reach the
power supply.
2 Remove the power
supply screw from the
rear bezel.
3 Pry the latch away from
the base of the power
supply.
4 Grasp the power supply
and firmly lift it out of
the drive mount chassis.
Note
: The firm lifting
motion disconnects the
power supply connector
from the logic board.
You can download the Service Source PDF here, it's about midway down in the right hand column:
http://www.retrocomputing.net/info/siti/...
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I answered your email and sent you the PDF.
さんによる
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 229
