メインコンテンツにスキップ
モデル番号A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5もしくは 3.4 GHz Core i7 Processor, ID iMac12,2
708回答 すべてを表示
Replace 1 TB Internal 3.5 Hard Drive with Dual SSD
I am wanting to replace the 1 TB spinning hard drive with two SSDs. I understand and have researched on adding a SSD and keeping the spinning drive but I am wanting to replace it with 2 SSD. A typical 3.5 hard drive should be more than the thick enough to cover the thickness of two Samsung 840 EVO drives that I am considering. Does a kit already exist that allows for this? I know Samsung makes a desktop kit that allows 1 SSD to be mounted in a 3.5 inch bay but that is only 1 SSD.
Also I have read some on special firmware on the Apple drive for temperature sensing, is that still accurate? Would I just be better off leaving the OEM drive intact?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
You might want to go here and take a look at Other World Computings solution called Data Doubler. As far as I know, its a kit that will allow you to add a SSD to your existing drive. If you were wanting to yank out the existing drive and substitute another SSD drive, I dont see a problem. But, OWC has tech folks on staff and give them a call or chat with a tech person and run that by them.
http://eshop.macsales.com/shop/drive_bra...
Hope this helps
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Matt さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 221
