メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
締切られた回答
Why wont my iPhone 4s turn on?
Today when i woke up i saw the charger was on 33% when i dragged it out of the charger i went to school, while i was walking i took my phone out of my pocket and it was turned off, i tried to turn it on again but it just got to apple logo and then turned off again. I tried even reboot the iphone some few times but it still turned off.
So when i went home to charge it, it wouldn't charge, i did even let it charge for 4 hours, nothing happend, i tried to reboot it while it was charging it still nothing happend
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Sounds like the battery connector is loose. Remove back and then disconnect and reconnect the battery.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Bad battery. You could try taking it to a Mac Store, an authorized repair store, or using the iFixit guide try and replace it yourself.
One last step to try would be a DFU restore. NOTE; it will wipe everything off the device.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I have plans to get a new phone, and i would like to get the pictures out of my iphone device, i dont want to change the battery.
Can i get my pictures without turning on the device with a computer by using itunes?
さんによる
My iphone 4s just back to normal again after 6 hours of charging hehe, but what was the reason?
It seems there ain't any problem with my battery, works prefect.
But time to time it shuts it self off when im not on my phone, when i turn it on it works,
さんによる
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 836
