メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
Replaced iPhone 4s battery and still not charging
I replaced my iPhone 4S battery with an iFixit battery following the tutorial to the letter.
The original problem was my iPhone just stopped charging, so I assumed it was a bad battery.
Obviously, this is not the case. When I plug the phone into the charger (on outlet and laptop) it immediately picks up connectivity and says the phone is charging, but the percentage is slowly dropping, not charging.
I thought perhaps the charging dock is bad, but wouldn't the connection be non-existent if that were the case?
What other areas could be the issue, and how can I verify the problem?
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
The low hanging fruit here is the dock connector---these are exposed to the elements on the outside so good chance of failure. Then a second battery. Then you'd think about board repair like charging coil, pry damage etc.
If you think about the 30 pin connector, each pin (more or less) does a different job, so it is entirely possible that detection works but not charging.
My bet is dock connector will solve on this one.
jessa
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Thanks for the reply! I already purchased a dock connector (because I thought that was the original problem since OEM battery had same issue).
So I'll take it apart again tomorrow and replace the dock connector, fingers crossed!
Will update status tomorrow!
Cheers :)
さんによる
Replacing the dock connector resolved the issue! I followed iFixit's guide and had a flawless replacement! Cheers!
さんによる
congratulations! I win another bet :)
さんによる
コメントを追加
回答を追加する
phoenix188 さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 572
