メインコンテンツにスキップ
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
1500回答 すべてを表示
No service or searching issue
Hi
I bought a logic board that was locked to a net work and jailbroken. I got it network unlocked and restored it.
It gets coverage in large towns but not anywhere else. I have checked connection no.7 and it is perfect also both gold prongs are touching the Bessel. The only thing I can see is on the back of the logic board, directly under the number 7 connector there should be a little gold round thing, and that is missing.
Any help would be greatly appreciated.
Update
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント
Post an image of your board with your question. This will let us see what you see in respect to "the gold round thing"
さんによる
[image|363660]
さんによる
Hi
I am not sure how to load an image, I tried and there is just a number.
さんによる
The round gold thing over the first screw hole bottom right. This is missing from my board.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Maureen Kelly, "The round gold thing over the first screw hole bottom right" is reference designator J5_RF and it is your cellular antenna connector. You kind off need that for your phone to function properly. It is a Murata MM8130-2600 and check the datasheet for the exact part on here. Please be aware that this part is very small, it does need soldering to be replaced. You will need some great skills and good tools to replace it. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Just to be sure, is this on the underside of the logic board as in picture.
Thank you for your help
さんによる
yes, that is where its at
さんによる
コメントを追加
回答を追加する
Maureen Kelly さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 167
