Is there connection between keyboard & it's support?
I removed the aluminum support bar that is transverse to the bottom of the keyboard. This bar passes over the open slot that is near the middle of the black plastic back cover that is glued around the keyboard periphery. I removed the black keyboard cover to access the bottom of the keyboard, which I then vacuumed away the dust and cat hairs.
What I failed to observe was if there was a part connecting the keyboard & the support bar that fit through the slot on the black plastic.
Is there a part there? What does it look like?
この質問は役に立ちましたか?
1件のコメント
Clay, it might help if you add a couple of images of the area in question. to add images, use this guide iFixitでの質問に画像を追加する方法
oldturkey03 さんによる
