メインコンテンツにスキップ
モデル番号A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5もしくは3.5 GHz Core i7 Processor, ID iMac14,2
340回答 すべてを表示
締切られた回答
Can I add a hard drive?
Hello all,
I've been mulling over a purchase of a 27" iMac, but I want to maximize SSD space. Unfortunately this comes at huge cost, so I'd rather leave out a HDD. I figure I can always find a good one on newegg or something on sale, so why pay Apple, right?
Anyways, I know the reverse of this question is true. One can add an SSD to a HDD-Only iMac, but can I add a HDD to an SSD-only iMac? Has anyone attempted this? I'll assume the SATA ports are open, and there won't be any data/power cables. Whats the right length for the cables? Is there a proprietary caddy? Mounting screws that aren't provided?
Any information would help. Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I think the real question here is if you can order the machine in without the hard drive.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Yeah you can order it with only a 256GB, 500GB, or 1TB SSD. That's why I'm wondering, as I'd rather have a larger SSD and then add HDD storage down the line if I feel the need.
さんによる
Then do it. Here's how to put a standard drive in when you're ready: iMac Intel 27インチ EMC 2639のハードドライブ交換
さんによる
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 188
