Samsung Galaxy S4 got wet, unit turns on but screen goes white
Why the screen doesn't show the apps, it just gets brightly lit. It rings and I can answer it but nothing in screen.
This probably means that the screen or the screen connectors have been water damaged. Luckily for you, it sounds like most of the phone is undamaged. Clean the connectors on the board and on the LCD with a toothbrush and isopropyl alcohol. If this doesn't work and the board's connectors appear undamaged, buy a new lcd. Remember to take all precautions when performing this task, ESD is very likely when you are moving your hand back an forth, as you would when using the toothbrush. Remember to ground yourself
このアンサーは役に立ちましたか?
Did ur S4 screen work?Herman?I have exactly the same problem!my screen responds with sounds and vibrations bu shows white
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 2,148
