メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Key has detached from keyboard
How do I (can I?) replace a broken key on the keyboard? It is the ]} key.
Update
Hi, I can see now how to replace the key! Great, but where can I purchase the replacement part (the plastic hinged frame, which has a missing top hinge pin)?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Could you tell us exactly how the key is broken? It will help us help you. Ralph
さんによる
Something small like that might best be found on eBay.
さんによる
コメントを追加
2件の回答
ベストアンサー
Keys are user replaceable
If the tangs are broken off you'll need a new key. If not one end (side or bottom) sides under a tang on the keyboard, the hinges pop into pins on L & R.
http://www.youtube.com/watch?v=JjRTQIfVT...
Good Luck,
N.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Great link if the question asker knows to click on it. Please make your links more obvious. You usually have very good answers but we aren't dealing with power users here. You still get an upvote from me.
さんによる
Thanks Machead3!!!
That worked perfectly and was a piece of cake!
I should have guessed there would have been some answers on YouTube.
さんによる
コメントを追加
Yes, keys are definitely replaceable. In fact, there are online shops that specialize in such thing. Check out http://www.laptop-keys.com to find laptop key replacement and repair kits.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
billgaskins さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 2,965
