メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2396回答 すべてを表示
no sound while recording video
If I'm correct the upper mic is the one that records the sound for videos and the speaker during calls.
This mic is not working. What can I do to fix this?
The mic works perfectly during calls (no speaker), while recording audio on whatsapp, and recording voice memos. So I know the problem is the upper microphone and not the lower microphone.
How do I fix it?
Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
7件の回答
最も参考になった回答
I have had this issue three or four times, usually after I installed an app like voice recording, or recently, streaming radio. So far, rebooting has almost always fixed it. Once, I did have to delete the offending app.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Here also: no sound on recorded video. Turn iPhone 4 off/on fixed it.
さんによる
コメントを追加
The iPhone 4 has this as a common issue and most of the time it can be fixed with a simple hard reset.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
The Proximity Flex cable for the GSM iPhone 4 contains the top mic, so if that is your problem changing that flex cable should solve the issue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
What joseA said the upper mic is located on the proximity sensor replacing this will sort you out
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
https://www.youtube.com/watch?v=Fvtxp8Va...
Check out this video 100% solution easy without tearing apart your iphone !!!
Like if it worked.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I used to use my iPhone 5s to record a show. Even though the show was extremely loud, my phone still couldn't record any sound. I searched the internet and found one answer: tear off the plastic cover on the back of the phone. I found there was a tiny hole besides the camera, which I assume it's where the audio inputs. I did record sound ever since I tore it off.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
hi,100000% change the dock connector,just done 2 iphone 4
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mel Dominguez さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 20,338
