メインコンテンツにスキップ
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459回答 すべてを表示
Charging paused, battery temp too LOW!?"
Hi,
i have this Verizon Galaxy S3 (I535) that is giving me this message: Charging paused, battery temp too LOW
there is no sign of water any where it connects to computer and to my TV without a problem i noticed a strange thing that when i put it in download mode and leave it on the charger it will charge ..
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
I have galaxy a5.
When plugged charging paused, battery temperature too low.Can't charging.
How to fix it?
さんによる
コメントを追加
3件の回答
最も参考になった回答
how to fix this probelenm
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Try borrowing a friends battery to test out. If their battery charges then the phone may be detecting that the chemical reaction in your battery may be occurring too slow, and the phone may think that the battery is too cold. If your phone still says that it's too cold there may be connections that cant handle the electricity intake and make be bottle-necking the charge, you may need a whole board altogether. But don't take my word for it, i work on IOS devices more often, I'm not too familiar with the anatomy of the Galaxy S
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Well in my day to day experience once you have this Error showing up in Samsung S3 or S4 replacing charging port helps. I have not had this problem with S3 but had with S4 I replaced the charging port and it worked perfectly fine.
So I think replacing charging port of Samsung S3 will eliminate the problem.
Thx,
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
toto さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 8
今までの合計 7,219
