メインコンテンツにスキップ
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
214回答 すべてを表示
Squeaking noise when start up on Maytag Bravos Quiet Series 300 dryer?
The dryer is squeaking when beginning a cycle
After it is warmed up or in use for a few minutes it seems to not be as bad
Is there an easy troubleshooting method?
Could it be a bearing or is it a belt?
Where do I begin?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 6
コメントを追加
2件の回答
最も参考になった回答
I find your photos of a repair on a GE dryer interesting, but this is not the same design as the Maytag (Whirlpool) dryers. The Bravos 300 series are very similar to the Maytag Neptune series.
To replace the two wheels (located inside the rear of the dryer) on which the dryer drum rides - these do wear out depending upon frequency of machine use and size/weight of the loads. The front of the Maytag machine must be removed, then slide the drum out, and use a ratchet with socket to remove the two wheels with their holding bolt. A kit containing all the necessary parts can generally be purchased through an appliance parts center for about $40-50. Be sure to have your model number when ordering/purchasing the parts.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
It's probably a worn out drum bearing. Here's a pictorial guide on replacing one: http://marksprojects.wordpress.com/2009/...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
rick さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 14
今までの合計 17,036
