メインコンテンツにスキップ
Samsungの第五世代Android携帯のGalaxyスマートフォンは2014年4月11日に発売されました。指紋認識、より高度化したカメラ、より拡大したディスプレイ、防水性などを含む改良されたセルラーフォンです。4つのカラーから選べます:黒、ブルー、白、コッパー
577回答 すべてを表示
締切られた回答
galaxy s5 change screen display
Hello my girlfriend's phone just fall down and the screen is like crap.. I m thinking to buy a lcd display and replace it I saw that it's easy but I want to know something the glue that is between the screen and the mid case exist at the new original screen? If not what I have to do? Thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
最も参考になった回答
iliasnikolaou23, I am not sure about the "easy replacement" :-) You should have enough adhesive retained on the midframe to keep the display glued. If not, and that is what I d in some cases, add a small amount of rubber cement to the areas. I do stay away from "Gorilla Glue" as well as crazy glue. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Any samsumg screen that comes as just a screen and needs glued is not original as all genuine samsung screens come with frame attached
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
That was for the s4. I want to buy glass with display glued. That I asked if exist glue at the glass ornot
さんによる
Good question actually. I am wondering the same thing.
さんによる
コメントを追加
I just did a replacement for it on my shop, is fairly easy to take the broken screen, if you carefully heat up the screen and remove it slowly, you may actually leave the original adhesive on the frame. also when pulling up, watch out for the sensor button, since the flex cable is right behind the lcd, which mean it stick to the back of it. Other than that it was simple to take out
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Here is a very good tutorial walking you through how to step-by-step replace a cracked Galaxy S5 display http://www.etradesupply.com/blog/how-to-...
Please kindly note: Samsung Galaxy S5 comes with the new water resistance performance. However, if your Galaxy S5 suffers breakage and need to be repaired, you have to be aware of some non-reusable parts that must be replaced to the new one when reassemble.
These parts are:
Galaxy S5 front housing adhesive / form tap
Galaxy S5 Bracket Cu tape
10 screws on the middle frame
3 screws on the rear housing.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
The screws need replacement to keep the phone waterproof?
さんによる
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 5,647
