メインコンテンツにスキップ
2012年、Sony Entertainment は2006年 Playstation 3コンソールの新モデルバージョンを発売することを発表しました。この新コンソールは、Playstation 3 Super Slimと呼ばれ、モデル番号はCECH-4000です。PlayStation 3 Super Slim (CECH400x) はSony Computer Entertainmentによって製造された第三番目のPS3ビデオゲームコンソールです。2012年10月25日に発売されました。
211回答 すべてを表示
ps3 wont read disk
hi everyone my ps3 super slim wont read any disk when i put a disk in it makes a few click sounds then like a engine rev, i can tell i spins the disk i put in but not 360 what Im saying is it spins ones then stops and i does not show that the disk is in i do not know why its doing this but two days ago it work fine then today i turn it on and what do you know. oh and its only two years old i got it in late 2012 everything else works on the ps3 i just hate to buy a new one because im high ranks online in most of my games gta5 bf4 gt6 bo2 ect
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 34
11 件のコメント
Well i been having my ps3 super slim for 6 months and two day ago i try to play gta online and my system said update to 4.76 .....so i did it and now it wont read any of my games what can i do to fix it.
さんによる
My console Can play PS1 Games however... still wont play other stuff like PS3 or 2 and no Blu-Rays
さんによる
well my system made the clicking sounds but it spinned but when the next day started i turned it on and now my system stops playing games completely
さんによる
I'm having same problem. I had to buy a new ps3 bc the one I got when they first came out tore up. My new one is a few years old. It just reads sometimes then not read sometimes.makes the clicking noise. But u can fix it by turning the lens a certain way. Just I'm not smart enough to do that :( don't worry if u buy a new ps3 it won't affect trophys any online ranks etc. Bc your online stuff is always there as long as u sign in with the same name. It has something to do with the lens. But if u do want to buy a new one u can probably get one round 20 bucks at yard sales or pawn shops. There's some games I need to finish. And play and my ps3 will not read discs. Also on mw3 it would freeze all the time after 2 hours of ejecting and reinstating the disc so it would read. Never been so mad in all my life. Cd players DVD players do the same thing
さんによる
Won't load a game. what Is wrong with it.
さんによる
6件以上のコメントを表示
コメントを追加
4件の回答
ベストアンサー
May just need the laser replaced. Follow this video guide found here
このアンサーは役に立ちましたか?
スコア 2
9 件のコメント:
bruh plzzzzzzz tell me how to fix the ps3 and im a high rank on gta5 im rank 289 plzzzzzzz help
さんによる
Plzz Help Sleeping Dogs Anit Working AND Bo2 Im mAster lvl Help
さんによる
My ps3 super slim wont load my games all i hear is a clicking sound. If i restore it will that solve this problem??????
さんによる
How can I make it read my games again
さんによる
I got a super slim but it wont read any discs what do i do?
さんによる
4件以上のコメントを表示
コメントを追加
最も参考になった回答
My name is Stephen.w and I'm here to help you. It's not the disc or the laser it's the disc stopper what your gonna need to do is remove the back panel and by the door of your disc cover you'll see a little plastic wing slide the cover back and there's your problem lift up the little tab and insert a small pick or something what I did was I got a small plastic pick and cut it in a angle and made one side big and the other small and dipped it in super glue and placed it in and that's it disc spins and now you can play. Now remember if wemon don't find you handsome they'll at least find you handy lol P.S for the PS3 super slim
このアンサーは役に立ちましたか?
スコア 3
9 件のコメント:
Please help mine won't spin I don't no how to do that
さんによる
Hey Stephen my name is Steven (no relation) ...i hav that same issue & i'm gonna try, whats a pick tho?
さんによる
Hi my name is kyle i took the disc stop out and still will not read
さんによる
It Didt Work i have a White Ps3 With a Sliding Cover
さんによる
Hey Stephen my name is Trevor can u do a video on YouTube plzzz
さんによる
4件以上のコメントを表示
コメントを追加
turn it off, hold in the power button until it beeps once twice and then a 3rd time, take your finger off. then hold it in again you will here it beep once then a short time after a second beep and a short time after that two close beeps take your finger straight off, ur system will turn on it will give u a list starting with restart your system, go for rebuild data base hope this help, u can try them all if this doesnt work
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Hey Stefan my name is Kenny I don't know if this post is still active or what anyway I have a PlayStation 3 slim it could be the super slim I'm not quite sure I know it's just the one with the sliding door on the top. When I put a disc in it spins but then eventually stop spinning and then starts spinning again and then stops spinning. The eye sensor is lit it seems to be trying to read the disc but whatever the boxes called that slides up and down the metal rods on each side of it one has twist going up the other is just a straight rod so therefore it cannot scan the whole disc I believe it's the problem because that's what I see I have taken it apart and the twist rod on the one side is connected and it does turn but it seems like the maybe the itself stops turning I'm not quite sure but I know it turns and I know it catches it just does not stay turning Maybe everything else I else works hopefully you understand this and if you have any ideas please reply I would gladly appreciate it thank you
さんによる
These way only works for slim ema. Loui
さんによる
I used a CD lens cleaner and I cleaned the inside and my games still don't work....
さんによる
コメントを追加
I have found a cure! On my system everything but the optical drive worked fine, no overheating and good picture. But the optical drive eventually would not read discs! At first I had to put it on its side (opposite side to screw-in vertical stand) and keep it there. That's ONE temporary fix..another that I soon discover when that eventually stopped working was MANUALLY SLIDING OPTICAL DRIVE TO LEFT POSITION BEOFRE STARUP. Found that it was very stiff and the motor wasn't able to move optics to "read" position and where simply stuck in open!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yeah how do u fix it
さんによる
コメントを追加
回答を追加する
mathewyazvac さん、ありがとうございました!
統計データ:
過去 24時間: 10
過去 7 日: 70
過去 30 日: 233
今までの合計 124,112
