メインコンテンツにスキップ
Mid 2010 Model A1278 / 2.4 もしくは 2.66 GHz Core 2 Duoプロセッサ
794回答 すべてを表示
MacBook won't charge with new battery and charger
My Macbook won't charge after replacing the battery and charger. My warranty is up and I don't have the money to send it in to be fixed. When I plug charger in, the light on the charger doesn't turn on. Sometimes if the charger is in perfect position it will charge for a few seconds and then the light will go off again. Any help would be useful.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Use a toothpick and move the pins in and out on the Power Adapter..Next use a multimeter to test the output of the pins and see if you get 16.5 volts. On the right of this wiki is a picture of the pin out: http://en.wikipedia.org/wiki/MagSafe
Next replace the Mag=safe board, here's how: MacBook Pro 13" Unibody Mid 2010 DC-Inボードの交換
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
If you look in that picture you will see a very thin white gasket around the pins.
I had same problem and it turned out for me it was just the insulating gasket in the external port. I found part of it still intact and guessed partial insulation might be that causing a short.
The gasket is made of very thin tape and sure enough when I made a copy and put that in, it charged fine on the new charger I had bought. The old charger is dead (on this and a friend's machine) so I presume it was fried shorting while I repeatedly tried to charge before. P.S. I made the copy of the gasket size needed by making an inverse template by pressing Blutac into the magsafe port hole and used that as a block to print an outline onto the tape. For me I didn't even need to open the mac up!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
zack さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 1,415
