The HTC Evo 4G LTE is an Android smartphone developed by HTC Corporation to be released exclusively by Sprint.
Gwen Mills @gwenmills
評価: 13
投稿日: 2014年5月6日
back key, home key and menu key are not responding to touch
この質問は役に立ちましたか?
Sophia @sophia84381
評価: 43.8千
64
44
41
If this happened after you install some apps, try to uninstall them and restart the phone to see if can help. If failed, the sensor flex cable in charge of these three soft keys may be broken, you need to send to repair.
Good luck to you!
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 5
過去 30 日: 11
今までの合計 569
