メインコンテンツにスキップ
Repair guides and support for riding lawn tractors sold under the Murray brand name, currently owned by Briggs & Stratton.
139回答 すべてを表示
Engine cutting off when brake/clutch pedal released
I have a Murray riding mower model 46503X8.
I depress the clutch brake pedal to start the engine. The engine starts easily and runs when the brake/clutch switch is depressed.
If I release the brake/clutch switch the engine shuts down. I replaced the brake /clutch switch and the pto switch, but the problem did not go away.
I did the following test. With the engine running and the brake /clutch switch depress, I engaged the cutting blades (pto switch) and the engine shuts down.
I have an electrical diagram but need help to solve this problem.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
Further checks revealed that the seat switch was defective. Once I replaced this, I was running and cutting the grass.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I had the same problem with the brake pedal but my seat safety switch was disabled before the problem arised.... and everything worked fine ???
さんによる
コメントを追加
回答を追加する
Harry さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 22
過去 30 日: 103
今までの合計 17,398
