メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2397回答 すべてを表示
Top and bottom of frame is bent outwards
My stepson's mom just got this iPhone 4 for him used and when it wouldn't stay connected to the charger I started looking at it and the top and bottom of the aluminium frame is bent outwards.
The phone is fully functional otherwise, it charges fine if the connector is pushed against it, just seems like the frame is preventing a proper connection.
Is this simply the frame that is bent, or could some internal problem be causing this?
Photos:
http://i.imgur.com/hfMKvfT.jpg
http://i.imgur.com/vVwxBZl.jpg
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
最も参考になった回答
No it wouldn't be the frame it's most likely charging port that's faulty could could try picking dust and dirt out of it to see if it makes any difference..
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
This iphone has obviously been involved in a very nasty smash sometime in the past which has damaged the chassis. If you take it apart you'll probably find the screen/back have been replaced before. Looking at your pictures yes the frame will be stopping the charger going all the way in.
Best option would be to get a new chassis/frame for it and fit it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
rosahildur さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 6
今までの合計 96
