メインコンテンツにスキップ
Repair guides for cell phones manufactured by Panasonic.
13回答 すべてを表示
Panasonic KX-TG5110 Cordless Phone will not stay charged?
Charge new battery but will not stay charged for more than an hour is that the norm. when they stayed charged the whole day phones are three years old
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
選択されたソリューション
Bob, the Panasonic does suffer from poor battery performance. It is a common complaint. You said staying charged for an hour, if that means that you can use it for an hour, that is actually pretty good. Anyhow, I would replace the battery one more time to make sure that the first battery pack was not of low quality. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Where do you buy the batteries if phone is 6 years old?
さんによる
rayford13 what model is your phone and where are you located?
さんによる
コメントを追加
最も参考になった回答
It could be a bad port that appears to be charging but does not. I have also seen devices with signal problems do this. It struggles to find the tower constantly so the battery runs down quickly.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
jamee, this is a 5.8GHz cordless phone. They are usually not plagued by searching for towers etc.
さんによる
コメントを追加
回答を追加する
Bob さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 18
今までの合計 2,987
