メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
showing 0146 error
hi
in my system also showing 0146 error but there is no any operating system install in previouslly
when i am trying to boot it will show
Winows failed to start . A recent harxware or software changes might be the cause .to fix the problem:
1) Insert your windows installation disc and restart your computer.
2) choose your language settings and then click next
3) click repaire your computer.
If you o not have this disc , contact your system administrator or computer manufacturer for assitance
status:0x000000f
Info :the boot seletion faild becouse device is inaccessiblle.
if there any solution for above error then plz post that ....
and i also change SATA setting SATA Mode under drive options to ATA from AHCI and save settings. but not working .....
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ganesh, you obviously already tried all the common steps. This error code most often correspond with a failed hard drive. To repair it you will have to replace your drive. Hope this helps, good luck
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ganesh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 114
