Why is my HDMI Port not working?
When I try to plug my camera into my TV via the HDMI port, the connection is fuzzy, or does not work at all. Is repair necessary?
Hi, Geremy. First, check to make sure that your connecting cable is securely plugged in at both ends. If that does not fix the problem, try gently cleaning the ends of the HDMI cable and your camera's HDMI port with a cotton swab.
If neither of these solutions are successful, it is possible that your camera needs a new HDMI port.
このアンサーは役に立ちましたか?
Great, so how do I replace the HDMI port?
Hi ,
is this an expensive repair ( @ Canon ) : HDMI port replacement...?
(I'm afraid mine is damaged)
Grtz , H.
このアンサーは役に立ちましたか?
Did you ever find out how to replace the HDMI port on your Canon 90d? I am in need of doing this and can't find a place to tell me how or where I can take it to get done! Thank for any info!
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 2,114
