メインコンテンツにスキップ
The dv5-1125nr is an multimedia entertainment laptop that features a 15.4" display, a built in camera, and toggle touchpad
Why is my touchpad not working?
Everything on my laptop works perfectly fine except for the touchpad, which won't respond to my touch. When I plug in a regular mouse, the computer seems to work fine, however.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi Nick. This problem could occur due to software disabling the touchpad. Check your control panel in Windows for mouse controlling programs that may have options to disable the touchpad. In addition, the dv5-1125nr has the ability to disable its touchpad with a button directly above the touchpad. It's a small silver rectangle with a light next to it. If the light is on, the touchpad is disabled. If you're still having trouble, you may need to replace the touchpad. Check the repair guides for the dv5 on its device page, and look at the troubleshooting page if you need any more help.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Nick Loey さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 9
今までの合計 912
