Why is my iPod not connecting through the docking cradle?
Whenever I plug my iPod through USB cable it will connect to my computer, but my iPod will not connect to the iHome. It will not even charge. Do i need to replace a part?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Steven Smalley, you did not tell us what model iPod your are using. You will have to make sure that your iPod is compatible with your iH5.
iPod Shuffle NOTE: iH5 will not charge iPod Shuffle
iPod Mini
iPod 3Gen 10-15 GB
iPod 3Gen 20 GB
iPod 4Gen 20 GB
iPod Photo 30 GB
iPod 3Gen 30 GB
iPod 3Gen 40 GB
iPod 4Gen 40 GB
iPod Photo 40 GB
iPod Photo 60 GB
iPod nano 1 GB
iPod nano 2 GB
iPod nano 4 GB
iPod 5th gen Video
anything else will not work due to a reconfiguration of the dock connector. If you are connecting one of those iPods and still have issues with that, replace the dock connector on your iH5. You'll find some good instructions for that on here. Hope this helps, good luck.
このアンサーは役に立ちましたか?
You may have to replace the docking cradle, but another solution could be bad wiring, or the iHome itself may not be recognizing the iPod, as is a common issue with this model. The iH5 doesn't charge certain devices such as the iPod Touch, but may still play with it.
このアンサーは役に立ちましたか?
William, how do you do that "replace the docking cradle"? How do you check the wiring? Why is this "a common issue with this model."? Why would it not recognize certain models? You are guessing and not providing solid answers.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 2,712
1件のコメント
What model iPod do you have and has it ever connected to the iH5?
oldturkey03 さんによる
