メインコンテンツにスキップ
Compact digital camera with built-in flash with 10.0 Megapixel, 10x Optical Zoom and Image Stabilizer System. Disassembling requires the use of certain equipment.
19回答 すべてを表示
My camera is showing "lens error/restart camera", how do I fix it?
My camera is giving me a "lens error/restart camera" message and the shutter seems to be a bit opened. How do I solve this problem?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 27
15 件のコメント
I'm also experiencing this error message, however...
• the camera turns on,
• the lens extends outwards,
• the lens contracts inwards,
• the camera turns off...
I did notice the superficial disfigurement that is on the outer shell of the lens, but this shouldn't cause this error as on occasions, the camera turns on, the lens extends outwards, and I can snap a few pictures, unless I aim the camera in any direction other than straight ahead - if not straight ahead, the lens contracts inwards & camera turns off.
さんによる
Try pointing the camera at the ground. This works for me EVERY time. Gravity is a ##&&%.
さんによる
I just got this error and had no clue what to do. tried pointing it at the ground and it worked! Thanks so much!
さんによる
My lens cover does not open?
さんによる
hi i have x50 and my wife droped it when it was on I need to take it apart and fix it any tips?
さんによる
10件以上のコメントを表示
コメントを追加
7件の回答
ベストアンサー
You are experiencing a common error. Normally this is a problem with the lens extension mechanism that is activated when the camera starts. This can normally be attributed to a dirty camera case or other grit getting into the camera mechanism. Other possible sources are physical jarring during operation or low battery during operation. The fist thing you should do is remove the existing batteries and the memory card from the camera, wait one minute and then put the batteries and the memory card back again into their compartment. Next, turn the camera on. Another possible solution is to blow compressed air around the lens mechanism, or a hair dryer on a no heat setting. Also, you can slide a piece of paper around the lens area and move it around the gaps in an effort to dislodge anything stuck in there.
このアンサーは役に立ちましたか?
スコア 16
18 件のコメント:
Thank you for your tips. I tried all of the above and still nothing :( I'm lost without my Canon Powershot SX120 IS as I never leave the house without it lol I will continue my search for an answer, as I'm leaving Aug. 1st for a beautiful sailboat trip to do some fishing..if by chance I find another way to fix this problem, I'll post it..
Thanks again...
Joanne
さんによる
Thanks so much!! Your solution worked for me!
さんによる
Same problem lens not coming out showing lens error don't know what to do pl help can I go to the service center please help
さんによる
Oh, Thank you so much ! This was helping ! The (old) camera functions again ! Marvellous ! Thank you so much ! :)
さんによる
Laying the camera flat on its back (lens up) and tapping it gently on a tabletop during startup caused the lens to finally open up.
さんによる
13件以上のコメントを表示
コメントを追加
I DO NOT RECOMEND DOING WHAT I DID to fix my error but i took the bottom of the lens and whacked it kinda hard on my thigh and i heard a crack, turns out i think my lens over extended and i set it back in place
このアンサーは役に立ちましたか?
スコア 4
4 件のコメント:
It worked for me also
さんによる
Thank you for the thigh trick. I was about to give up and tried this and it worked.
さんによる
Thank you so much. It did work on mine too. You do guys dont know how much you made me happy.
さんによる
I tried it and now my thigh hurts and camera is still having the problem
さんによる
コメントを追加
My 3 year old dropped my Canon SX 280 HS camera (hope this is relevant) with the lens extended. After about half an hour trying must of the suggestions on this page I reached a new level of frustration. I tried swishing a piece of the paper round the gaps. A tiny piece of paper broke off and stuck inside. To solve this particular issue, I effectively bent the extended lens to create a gap so the paper would fall off, dangerous I know. Then I heard the click that made me think it was finally ready for the bin but hey presto it started working again!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
That worked for me, tried each section of the lens; heard a click on a couple of them and the camera now works. Thanks for the help
さんによる
コメントを追加
I had the same problem with my Powershot SX120.
I found that the spring for the batteries had gone a bit down. Fixed that and problem seems to be solved.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
how can i fix my powershot sx610 hs?
さんによる
コメントを追加
Do:
Clean the Lens and if something is obstructing the lens movement, remove that to fix EOS error.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Point it down to the floor as if u r picturing the floor and press those buttons again. A miracle will happen then.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My daughter had this problem with her Canon SX20-IS. Her lens was stuck at full extension. I tried all of the fixes and nothing worked.
She accidentally left it in her car overnight, where it got below freezing. The next day, it started working!
It might sound crazy, but if all else fails, try sticking it in the freezer for a couple hours. Not sure if this could possibly damage camera or not.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Maria さん、ありがとうございました!
統計データ:
過去 24時間: 37
過去 7 日: 339
過去 30 日: 1,410
今までの合計 117,096
