メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
GSM iPad 2は16、32、64GBの容量オプションがあり、Dual Core A5プロセッサが搭載されています。モデル番号はA1396。修理作業は複雑で、ヒート(熱)を当ててこじ開ける作業が必須です。
My iPad's screen has wierd colors.
Okay so my iPad was dropped on the floor, the screen went black but when I press the lock button it showed a little light, I found a solution here, I smacked the iPad and the screen turned on again, but the screen has wierd colours like orange - red - green - blue greeny and I tried to search here for solutions but I didn't find any. So can I fix it with smacking again or do I have to go and change the LCD or what? And thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
6件の回答
最も参考になった回答
I'm definitely no Ipad pro, but if you are comfortable with DIY solutions I would suggest simply opening the Ipad 2 (remove the digitizer) and ensure that the LCD coord is seated correctly. What happened when you dropped it in the first place was the cable got slightly unseated, and when you smack it (sometimes) it gets back into place.
I have customers who come in once a week saying they need a new LCD, 6times out of 10 I simply unconnect and reconnect the cable and it works as it should.
If reseating the coord does not fix the problem, then you will indeed need to purchase a new LCD for your Ipad.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Before you go tearing it apart , try some more smacks. Be sure to go around all the four corners. If this doesn't work after a few tries, then go with Alexanders advice. Make sure the iPad is powered off before disconnecting/reconnecting the LCD cable as you could blow the backlight filter if it is still powered on.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Smack the back
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Lovely! It worked like a swiss clock.
さんによる
I tried it and to my surprise it worked
さんによる
Give it few slaps, still getting array of colours. What next? Thankyou.
さんによる
コメントを追加
Another thing to verify...make sure you didn't activate the "Invert Colors" option. This will effect all the colors. It is possible the home button is programmed to activate it by pressing 3 times quickly.
To verify:
1. Go to "Settings"
2. Scroll to "General"
3. Make sure the "Invert Colors" slider is to the left for normal operation.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
So I dropped my iPad and had the red screen. Tried smacking it and didn't help. Went to check invert colors and it was off but I slid it over to see what it would look like. Decided I didn't like it and switched it back. Went to home screen and all was fixed
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
iPad color change issue started after I purchased a after market non Apple charging cable. There were no problems at first. It was a couple weeks later before the color change occurred. Took it to Apple store. Said to buy a new one. Well no thanks, I’ll wait to upgrade to the Pro. I decided to only use the alt cord when I was too far from an outlet. I started using the original cord again to charge the iPad. After several charges and complete discharges, the last one sitting for 3-4 days before charging, the color changed back.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Xobic さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 22,035
