メインコンテンツにスキップ
The Nokia Lumia 920, developed by Nokia and released in November 2012, utilizes Windows Phone 8 operating system.
56回答 すべてを表示
Battery drops from 100% to 7%
I bought this phone from eBay. Turns out it would only turn on unless I charge it for hours! So I bought a new battery and it began charging and turning on. I disconnect it and it would be fine for like 2 or 3 minutes. Then it would all of a sudden drop from 100% to 7%. I don't think its the battery because I bought an OEM battery. But it could be defective. I'm not sure. Any help?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
2 件のコメント
Does any part of the phone overheat?
さんによる
No. Not at all. It works normal then the battery power just drops.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Sounds like there may be a task left open in the background. Press and hold the back arrow to see if there are any tasks left open? If not try a soft reset first by pressing and holding the vol down+power button. You shouldn't lose any data doing this but some have reported their clock resetting.
Another thing to check. Goto settigs>Applications>photos+camera. Is Auto upload to Skydrive on or off? If it is on, your phone may have apent hours trying to upload to Skydrive if you have a slow internet connection. If connection is slow, you might want to consider turning this off.
If all else you may need to replace the battery.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jon Andrade さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 395
