メインコンテンツにスキップ
A tablet developed by HP in 2011 running the webOS platform. Boasts a 9.7" display, and is available in 16 or 32 GB. Repair is straightforward, but requires time and persistence.
app catalog update fail in tablet
hi all, pls look into my query regarding unable to install app in my HP touchpad. While I am installing any app from app store there was error msg of install failed after completion of application.
so pls look into this and resolve this case as its very much urgent.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
This link will show you how to fix your problem so you can update the app catalog
. https://developer.palm.com/support/appli...
1.     For users of ALL webOS devices:
a.      Open the “Date & Time” app on your device.
b.     Set “Network Time” to Off.
c.      Set the date to July 1, 2013.
d.     Open the App Catalog
e.      Type “App Catalog Update” in the search filed, and select “Enter” on the keyboard.
f.      Tap the “App Catalog Update” app to display the details page.
g.     Tap “Download for Free” to download and install the app.
h.     Return to the “Date & Time” app.
i.       Set the date back to the current date.
j.       Set “Network Time” to On.
Note: Once the appropriate update is installed, the certificate is renewed even if the user later decides to reset the device (partial or full erase), or deletes any of the updates discussed here.
It is possible for users to install both an App Catalog update, and the “App Catalog Update” standalone app. Although not necessary and redundant, there is no harm in doing this.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
jaymin patel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 2,672
