Htc One M8 replacement parts
I've been looking online for replacement parts for the new Htc One M8 but have only been able to find the case . Are any other replacement parts for the M8 available and if so, where.
What replacement parts do you need? The replacement parts for newest device always come slowly. Tell what you need and we can find from the market than put on our website witrigs.com, hope can help you.
このアンサーは役に立ちましたか?
I need a gun metal back housing because I dented the back of the phone . I wonder if I take the back off if I can just push on it from the inside if that would work.
このアンサーは役に立ちましたか?
Hello,
I'm looking for a Herman Kardon rear case, do you know where I can find one?
I just find "normal" rear case
thx
このアンサーは役に立ちましたか?
try to search mobile parts in this website http://www.phonelcdwholesale.com , it is professional cell phone parts wholesale supplier.
このアンサーは役に立ちましたか?
my hardware volume buttons are gone and i am looking for any replacement for my gray m8.. is anyone has a knowledge where i can found those buttons?
このアンサーは役に立ちましたか?
i have m8 back covers
このアンサーは役に立ちましたか?
Hello Jeff, i am hoping you still have an m8 back cover available, if so how do i buy one from you? (1st time on this site so unsure how to contact, please pardon my ignorance) i have the same issue with my m8 (dent on battery cover) except that the ribbon wire that encircles the lower camera port was cut. What seems to be unique is the ribbon wire is not pictured anywhere on m8 back covers. Could this be something installed by the carrier? (t-mobile). The shape and color of the wire is very similar to the ones used on m7's. I'll try to attach a pic.
I had the same issue with my volume button on HTC One M8. HTC would not cover it under warranty.
I was able to purchase a new volume rocker from parts4repair.com for only $3.50, however it is still loose and does often fall out at times. It is also quite tricky to get it in there, I have to use a sharp tool to guide it back in.
It's not perfect, but it does the trick.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 6
過去 30 日: 17
今までの合計 15,156
1件のコメント
This website provides all kinds of replacement parts for HTC. You can visit for more. http://www.dbx.com.cn/Category/HTC-Parts...
Martin Benitez さんによる
