メインコンテンツにスキップ
1.8 GHz デュアルコア Intel Core i5(Turbo Boost使用時最大2.8 GHz)3MB L3キャッシュ
Replacing the motherboard with 8GB RAM, can I?
Hi,
My motherboard is gone due to a spill (advice: if you spill something in the macbook, just bring it in a repair shop for cleanup, as mine lasted 6 more month but would have been OK if I had cleaned it properly).
Anyway, since I am replacing logic board and top cover anyway, I thought I might put in 2.0Ghz i7 with 8GB of RAM instead of the original 1.86Ghz and 4GB.
Are there any incompatibilities between the logic boards of the same year if I put higher end internals? Given that the logic board that I replace with is from a MacBook Air 2012 A1466 same as mine..
Any thoughts? :)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
sviests, for as long as you stay in the same year/group you should be okay with a swap. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
回答を追加する
sviests さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,042
