メインコンテンツにスキップ
The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
60回答 すべてを表示
Problem with wifi signal level after repair (changing LCD display)
Hi,
after replacing the LCD unit of my Razr XT910, I got a problem with very low wifi signal level. Is it possible that I have damaged the wireless antenna ? The GPS is not connecting, too. However, it was not connecting before I replace the LCD. I am still in doubt where it is really positioned the wifi antenna.
Best regards,
Heron
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
With little documentation out there, and not having that specific model on me I looked at a couple of teardowns and images of the parts. There is two antenna's I can see on the mid frame (rear housing). One near the top, the other near the bottom. The larger of the two will most likely be cellular.
There is also a possible antenna on the LCD flex cable. I would generally think its a IC but from lack of traces leading to it, just can't be.
As for the GPS, antennas are usually in the controller for it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Heron Carvalho さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 1,198
