メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
Burned camera lens .
Hello
I am a medical student and i used my mobile camera to take pictures from a microscope but i think the extreme light from the microscope burnt the lenses because when I try to take pictures in low-light occasions the picture I get is red and pink.Can I fix it ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Did this happen recently or has it always acted this way in low light conditions?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
This is not an uncommon issue it would seem, several HTC 1 users have run into the same problems, HTC has officially acknowledged the problem and believe that it may be a firmware issue with the phone. This was acknowledged last year, if you can, I would see if there is a firmware update as HTC believes it is a software issue. If you cannot wait and you are still under warranty you should be able to ask for a replacement if it is in fact the issue.
Also I would try to lower the ISO levels. HTC is advising users to reduce the ISO levels to lessen the impact of the flaw, or return their handset and receive a replacement.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thank you for your response
さんによる
Of course, I hope that helped
さんによる
コメントを追加
回答を追加する
Demetris Fkiaras さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 20
今までの合計 3,208
