メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
Changed screen on my iPhone 4, now it wont charge.
I changed a screen on a iphone 4. And now it wont charge. I have checked the flex cabel to make sure its properly fited, i even tried to change the dock connector. I have also tried with another battery. Any ideas? I am not feeling good about this, because i did this repair for a friend...
EDIT:
I have now tested the phone with a motherboard forom another iphone 4, and now it charges fine. So i guess its a problem with the motherboard? What should i do now... Any suggestions?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
最も参考になった回答
Check all connections and clean it make sure that everything is not damaged or burned then unplug everything and put it all back together and put it on the charger maybe that can solve the issue. Hope this helps.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It's possible you damaged componants on the board. Did u pry the battery off against the board?
このアンサーは役に立ちましたか?
スコア 0
12 件のコメント:
I pryed it up from the battery side. So the spudger was laying on to the battery when i pryed it.
さんによる
Did u pry on the volume lets side or logic board side?
It's also possible that when unclipping the dock connector a componant was knocked off also.. Can you inspect for damage?
さんによる
Here is a picture of the connector: http://imgur.com/pRqjczv
I have inspected the connector and everything looks fine. Sorry for bad quality picture, I will upload some better ones tomorrow. I pryed the connector up from the volume bar side. Thank you so much for helping.
さんによる
I doesn't seem damaged to me. What do you think con?
さんによる
Here is another picture: http://imgur.com/Cca9HXN
さんによる
7件以上のコメントを表示
コメントを追加
回答を追加する
Iver さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 479
