メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
No cellular service on my iPhone
After the screen repair my iPhone's could not find my cellular network. I have tried to do everything to fix it but nothing worked. So I decided that i am going to replace the cellular antenna, does any one know how to or have a link to a nice guide?
i found the component i need
iPhone 5 Cellular Antenna
any ideas?
iPhone 5 Cellular Antennaの画像
製品
$9.99
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
Did u take the battery out? Only reason I ask is there could be pry damage If you did.
The antenna you are looking for is attached to the dock and Is the little black thin wire that clips into the bottom of the logic board make sure it's still plugged in..
If it was only a screen replacement then you should not have damaged this part
Also make sure the two long black cables that run up the middle of the logic board are clipped in
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
I didn't take the battery out, all i did was disconnect it.
i made sure and every things seems to be plugged in good ;/
さんによる
There are little componants all around were the battery connector is my guess is you have knocked one off
さんによる
so you think its the motherboard then?
さんによる
It could be I would open up and inspect for damage around the battery connector
さんによる
I inspected it very carefully, I see nothing that's not normal.
さんによる
コメントを追加
回答を追加する
Jon さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 729
