メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
new LCD not responding
This a has probably been touched on before, but here I go. I replaced the LCD and digitizer on an iPhone 4s, the original screen worked fine but had a small crack. When the new screen was attached I noticed that it would not display anything. I tried to pinpoint the issue by reconnecting the old screen to see if it was due to the replacement being faulty.. The old screen still worked fine. I tried to restore the iPhone to combat any software issues that may be causing the problem. Not only did the new screen still not work, but now the old screen won't even display anything !! Its running on ios 7.1 now after restoring previous was running on 7.0
Someone please help !!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
The old screen still worked fine. = the new lcd assembly was defective. this is totally common.
now the old screen won't even display = the iPhone doesn't like you to plug and unplug the screen when the battery is connected. it sounds like maybe you were doing a lot of plugging/unplugging in which case it is likely that you may have damaged the backlight filter.
Either way, return your screen and order a new one and then update here.
Here is a link that may be helpful for checking backlight filter continuity. You would use your multimeter set on 'continuity testing' to determine if there was continuity across these filters in red/orange on the picture
|iphone 4s backlight troubleshooting]
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
Is the backlight filter is on the LCD assembly itself or on the device
さんによる
The backlight filter is on the logic board
さんによる
Is there any way to be absolutely sure its the backlight filter (if that's the case ?
さんによる
And can I use the backlight filter from an iPhone 4 logic board ?
I appreciate all of the help
さんによる
You can check the backlight filter for continuity if no beep--thats the problem
さんによる
コメントを追加
how do i check for continuity ?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
frank rijo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 162
