Getting no signal since replaced charging dock iPhone 4
I replaced the charger and it now charges but my phone can't get any signal now I've checked the silver plug next to battery plug and its on what can it be ?
Look very closely for pry damage on board from battery removal if time/date are correct
このアンサーは役に立ちましたか?
Date and time are incorrect what is the issue now then?
No it keeps going wrong then correct
Connect to wifi then toggle airplane mode on then off and see if that solves
Try this unhook the little cable that is near where the battery connector goes.
repeat step 10 and unhook then rehook the cable. make sure it is on tight but dont force it
このアンサーは役に立ちましたか?
Is the time and date correct?
このアンサーは役に立ちましたか?
Connect the phone to iTunes on the laptop it will change the time and date for you.
Or go to setting then general and time and date and set to auto.. Make sure your connected to wifi
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 89
