メインコンテンツにスキップ
A new iteration of the set-top box, a side-set box. Chromecast connects to your Wi-Fi network to stream content from your compatible device to your television.
Red light no matter what?
Hi, I have a google chromecast and when I set it up everything worked perfectly. I unplugged it for the night and then I plugged it back in and it had a red light. I tried factory resetting it but the light still stayed red and the reset button is not stuck. Anything that I can do?
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
4件の回答
ベストアンサー
Try swapping out the USB cable that comes with it, apparently several people were given a cheap faulty USB cable that would stop working after a day or two. Many have found salvation by using a known good USB cable. Let me know if this doesn't work. Oh as far as the reset button you should feel a definite click, if you don't press the button repeatedly to loosen it up.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
Changing the usb cable worked for me. thanks so much!! such a simple solution but had me stumped. thanks again.
さんによる
I have an original 2013 Chromecast and it just stopped working now - July 2022! I know this is an old post, but just commenting as I came across this, and tried changing the cable as a last attempt before throwing it away and it worked!
さんによる
コメントを追加
Hi
Mine did the same. My Ccast remained plugged in and working great for a few months. Then one day, I noticed the LED was off.
I have tried many power supplies and cables. No luck. Even with a USB inline volt and ammeter plumbed into the supply. It shows no current draw from the C-cast.
Anyone else have this. ??
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
i am using the chromecast 2 audio only mode with 4k hdmi converter, red light always blinking bt it extracted audio perfectly.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
When I turn on the chrome cast the white light is blinking. But it is not showing in my device
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ted Mayer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 34
今までの合計 26,453
