Why is gas mixing in oil in 2004 Kohler CV740s engine?
when it cranked up it blew gas and oil out the breather on the valve cover approx 6 feet and leaked down on the muffler and caught on fire. I put it out but don't understand what caused it. How do I repair it?
この質問は役に立ちましたか?
3 件のコメント
How did you have the engine stored? Did your recently transport it. Check your float valve and see if it is stuck open.
oldturkey03 さんによる
No it was in my carport since last fall and I went to crank it and it blowed gas out of the valve cover about 6 feet and dripped down on the mufler and caught on fire. And I mean a big fire put a lot of water on it to put it out. But i am afraid to try it again without knowing what caused it. My oil case also has about gal. of gas in the oil. don't know if it might be intake crack or head craked or something else? Thanks, Charley
frankly さんによる
Thanks so much, i am unable to check it until this weekend but I will . Let you know what I find out. Thanks
frankly さんによる
