メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
1.6または1.8GHz デュアルコアプロセッサー、 2GBまたは4GBのSDRAM, 64GBまたは128GB SSD
3 Long Warning Beeps
Hello all, today I heard, for the 1st time, a sequence of 3 long beeps from my MacBook Air 11' mid 2011. It was in sleep mode but felt extremely hot. Also I noticed that the battery had gone from 96% when I put it to sleep to 65% in the 15 minutes that it was asleep! When I opened it up it didn't start, pressed the power button for 5-6 seconds and thankfully it powered up and I was taken to the login screen. Have been using it now for last hour and battery use is normal.
After some frantic googling it seems that the 3 beeps are a warning for bad ram? Is it possible to swap out the ram? Would be confident enough of opening up my beloved, have previously used ifixit for iPhone 3G & 4 parts/guides so hopefully this can be done!
thnaks for taking the time to read my question :)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
The RAM on your machine is "onboard", that is built into the logic board. It cannot be changed or upgraded after purchase. I would keep a everyday Time Machine hard drive (SSD) backup. Your machine could last a long time or it could fail in the next 5 minutes. "Therefore keep watch, because you do not know the day or the hour."
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
thanks for the quick reply :)
さんによる
コメントを追加
回答を追加する
collinsmikep さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 834
