メインコンテンツにスキップ
モデル番号はA1059もしくはA1099/20、40、60GBハードドライブ/タッチ反応クリックホイール
227回答 すべてを表示
Can a 40gb+ really be installed into a 20gb iPod?
I am getting conflicting information on this. I am just wondering if I can install the 8mm (drive height) drives such as a 40 or 60gb into my 20gb iPod. The 20gb drive is 5mm tall. Someone else here answered this exact question by saying you could but you would need a new drive holder part... Perhaps thinner rubber piece to go around the drive?
The real reason I want clarification is that I believe the 40gb iPod was thicker than the 20gb.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
Yes, see this previous answer, it has all the instructions you need.
Edit: If you want a little more clarity, you need to replace the following parts,
1) rear panel
2) headphone jack
3) headphone jack cable
And you can get a 60 gig drive here.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
My 20gb 4th Gen iDie Hard Color, model A1099, lost his mind after I dropped it from 2+mtr high on a concrete floor. I ordered a:
64GB KingSpec 1.8-inch IDE CF 50-pin SSD Solid State Disk (MLC)
to replace the original KIA 20gb HDD. Within 24hrs I received the 64gb KingSpec SSD.
I used iFixit's "iPod 4th Generation or Photo Hard Drive Replacement" as my DIY guide.
A good thing to know is that the 64gb KingSpec SSD has the same size as the original 20gb HDD so you don't have to buy a 40/60gb thick rear panel, 40/60gb headphone jack or bracket. Connecting the KingSpec SSD is exactly the same as connecting a HDD
When I was done I attached the iMod to my Laptop. Right after that I got a "iPod Firewire AC Charger" logo on my iMod screen. When I attached it to the AC Charger the "iPod Firewire AC Charger" logo disappeared and the "battery is fully charged" logo appeared. Right after that I connected my iMod again to my laptop. Because iTunes recognized the iMod it started itself up. After I choose "Restore iPod" in iTunes my iMod was within one minute fully functional again. Time will tell if it became a "iDie Harder" ;-)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jacob D さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 927
