Sreen goes blank for 3-4 sec
My laptop works great except a occaally the screen goes a dark gray for 3-4 seconds, then comes back. Any ideas? Thanks.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Graphics chip, OR it cold be cables shorting. There's "known issues" with the solder joints failing over time on these graphic chips. Shimming helps, reflowing the solder is a temporary cure. Damaged cables can be replaced.
If this answer is acceptable please return and mark it.
Good Luck,
N.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,032
1件のコメント
Plug it into an external display, does the problem persist?
originalmachead さんによる
