GPS is intermittent after replacing battery
Replacing the battery went well.
BUT . . . my GPS now works intermittently. Any ideas what happened?
Check the interconnect cables they ate the long black cables that run up the center of the logic board they control the gps and download signals
このアンサーは役に立ちましたか?
Did you pry on the logic board side when replacing battery?
Make sure the connector below the battery is connected and that the interconnect cables are connected aswel
このアンサーは役に立ちましたか?
Same problem here. Well, similar. My location just drifts and skips around now. Makes my GPS tracking app results hilarious but useless. I'm gonna break it open and check the cables, but any suggestions beyond the one above would be welcome in case that's not the issue.
このアンサーは役に立ちましたか?
Yup. I opened up the case earlier this evening. That connection seemed to be floating. I haven't had a chance to test it over a long distance yet, but the GPS location already appears to be more accurate. Pretty sure I must have dislodged that cable when replacing the battery. If I'm wrong, I'll report back. Pretty sure that was it, though.
このアンサーは役に立ちましたか?
Thank you, thank you, thank you. I too had replaced my battery and then lost GPS signal. Sure enough, the connector was loose. Tough little bugger to seat properly but I got it. Saved me a trip to the repair shop.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,516
