メインコンテンツにスキップ
The Creative ZEN is a small MP3 player about the size of a credit card. It was announced in August of 2007. It is flash based, with a 320x240 screen. It can play MP3, WAV, WMA and AAC (DRM-free) files.
What is the connector called that is being used?
What is the name of the connector or connection for the display? My player broke and i am thinking about a good way to put the display to good use. Is there any hope?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Peter, not quite sure what you are asking. You want to use the LCD for something different?
さんによる
Yes, i want to use the LCD for something different. I don´t know what Controller or Connector.
http://i.gyazo.com/038e90d37b4978f565f91...
さんによる
コメントを追加
2件の回答
ベストアンサー
Peter, that is just the ribbon cable and a 51 pin fpc connector. In order for you to utilize the LCD display in some other manner, you will need the datasheet for the LCD. That will tell you what the connections on the display are and what signal they carry. Take a look at the LCD and see if you find any manufacturers markings. Armed with that, you will have to find a circuit that can drive the LCD and a backlight to illuminate it. Not an easy task, but with some luck there is always the chance that something can be made to fit. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Thank you for pointing me in the right direction. I managed to find a data-sheet that seems to be the lcd. I´ll link it here. I am not a tech savy but i´ll keep trying.
http://www.maxim4u.com/view_download.php...
さんによる
Excellent find. Page 12 is perfect to see if and how to interface it to something different. What did you have in mind?
さんによる
I was thinking about connecting it to my raspberry pi. But it seems to be beyond my knowledge.
さんによる
コメントを追加
Hi, I d like to put this screen on my raspberry pi b+ too. It works for you? I suppose it is not possible just put the ribbon on the "display" slot?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Peter さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 711
