メインコンテンツにスキップ
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
318回答 すべてを表示
circular dots flashing around the timed area
I suddenly have flashing dots going around the area where it shows how much time is left for drying. Is this something I should be concerned about?
. 45 .
Similar to the above and dots move in a circle.
The dryer is working properly.
Please let me know.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
What does it mean if it’s doing that same thing on my Samsung washer
さんによる
Did you ever figure out what it is for a washer?
さんによる
コメントを追加
2件の回答
ベストアンサー
This is true for a Samsung dryer and may work for you:
Rotating blinking lights in the display is probably an indication that the Wrinkle Prevent option has been selected. Wrinkle Prevent will continue to tumble the dryer without heat after the cycle has ended to help prevent wrinkles from setting in. When this option is selected by pressing the Wrinkle Prevent button on the control panel, the display will count down the estimated cycle time; when the cycle ends, the display will show lights blinking in a circular (or actually rectangular) motion.
To deactivate, simply press the Wrinkle Prevent button again so the light is not illuminated.
このアンサーは役に立ちましたか?
スコア 10
8 件のコメント:
Thanks for taking the time to provide a response. That was definitely our issue and your answer helped us fell better. Have a good one.
さんによる
Wow! Thanks so much for this much needed advice. We had the same question and happen to also have a Samsung dryer and that is exactly what it was. Thank you for posting that answer which saved us a lot of time and headache:)
さんによる
Thank you! I had the same problem and thought oh no! Do I need to call a repairman? This was indeed the problem. It must have been pushed by accident and we didn’t even realize it.
さんによる
Thank you!!!
さんによる
Thank you for your response! This was the case for my Samsung dryer as we recently started using the Wrinkle free option! Glad to know that dryer is working ok. :)
さんによる
3件以上のコメントを表示
コメントを追加
This isn't true for my fridgidare . I cleaned the ducts inside and out and it still shows the dang dots???? Help pls
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
debbie さん、ありがとうございました!
統計データ:
過去 24時間: 21
過去 7 日: 101
過去 30 日: 554
今までの合計 45,319
