メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
Silent/lock button causes intermittent vibrate
Hi all,
Odd one; keeping the Silent/lock button in the off position seems normal. Once the button is switched to silent/lock mode it activates and displays the transparent logo with a line through it, meaning the mode is active, thats normal too. However, intermittently the logo will show again with a vibration showing its now off, and then again with a vibration to show its on again, this continues at random intervals and sometimes multiple vibrations and logo flickers.
Anyone had this before? - I've checked the vibration module but not the headphone jack flex assembly yet, just want to make sure I'm not missing something before I open up.
Quick bullet point summary:
• Vibrate/silent switch intermittently vibrates and displays silent logo once switched on.
• Vibrate/silent switch physical movements seem solid.
• All other buttons work OK.
• Headphones working OK.
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
3件の回答
ベストアンサー
It sounds as if the flex cable as went a tab faulty a new flex should sort out your problem that's the first step in the trouble shoot..
Oh you could also just restore to rule out corrupt software
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
thanks con, thought so, will tear down and check connections, rebuild. If no good ill replace the flex. :)
さんによる
No probs if changing the flex doesn't work your probobly dealing with a motherboard issue.
さんによる
コメントを追加
Will, Can you give me information about did changing flex cable solve the problem or not? If not what did you do to solve problem? Thanks.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Sorry, yes - I had changed the flex cable and ensured the vibrator motor was seated correctly touching the contacts (and that no other dust/elements where making contact with them)
All seems ok now, thank you!
さんによる
コメントを追加
Hi, I have the same problem. This flex calbe I have to change, could you tell me what that is?
Thanks
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The volume button ribbon cable which has the the vibrate / silent switch connected to it as well.
さんによる
コメントを追加
回答を追加する
Will さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 14
今までの合計 6,207
