メインコンテンツにスキップ
24" display; Built-in iSight Camera, Microphone, and Speakers; 1920x1200 resolution. Released October 2008, identified by model number A1267.
84回答 すべてを表示
締切られた回答
LED display won't show anything
Hi Guys!!
I have a 2009 Apple LED 24" Cinema display. My problem is that the LED panel won't show anything. The USB port and the charging cable and the speakers works just fine. But the display won't show anything when i plug it into my Macbook. Do you have any idea witch component has malfunction?
Thank you guys!! :)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Are you able to see a faint image shining a flash light at the screen at an angle? If you do then you know the LED back light driver is blown.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I will try to look after that.
If it some how shows that its not that? Do you know what else it could be?
Thank you for your help!
Kasper
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 1,891
